Помощь
PlayStation 3 Wi-Fi/Bluetooth Board Replacement
Replace your PS3's Wi-Fi/Bluetooth board.
  • Автор: Walter Galan
  • Времени уйдёт: 30 мин. - 1 час
  • Сложность: Средняя
Use this guide to replace the circuit board responsible for Bluetooth and Wi-Fi connectivity.
Разделы
Инструменты
Шаг 1 Wi-Fi/Bluetooth Board  ¶
If necessary, peel the memory card reader ribbon cable off the Wi-Fi/Bluetooth board.
  • If necessary, peel the memory card reader ribbon cable off the Wi-Fi/Bluetooth board.
Шаг 2  ¶
Use the flat end of a spudger to pry the Wi-Fi antenna connector up from its socket on the Wi-Fi/Bluetooth board.
Шаг 2  ¶
  • Use the flat end of a spudger to pry the Wi-Fi antenna connector up from its socket on the Wi-Fi/Bluetooth board.
Шаг 3  ¶
Use your fingernail to flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
Шаг 3  ¶
  • Use your fingernail to flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
Шаг 4  ¶
Remove the four 9 mm Phillips screws securing the Wi-Fi/Bluetooth board to the chassis.
Шаг 4  ¶
  • Remove the four 9 mm Phillips screws securing the Wi-Fi/Bluetooth board to the chassis.
Шаг 5  ¶
Remove the Wi-Fi/Bluetooth board from the PS3, minding any cables that may get caught.
Шаг 5  ¶
  • Remove the Wi-Fi/Bluetooth board from the PS3, minding any cables that may get caught.
