Помощь
Техника: How to descale and maintain Gaggia Classic Espresso Machine
Нужно больше изображений
Несколько изображений сделают это руководство более понятным.
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
How to tear down the Gaggia Classic Espresso machine to fix problems with scale and worn gaskets.
  • Автор: Kate Morris
  • Времени уйдёт: 2 часов
  • Сложность: Средняя
Espresso machines need to be descaled regularly to remove mineral buildup. After I had owned the Gaggia for 2 years, with regular (every 6 weeks) descaling, the machine was struggling to pump enough water to make a decent cup of espresso. Sydney does not have a much mineralization in the water, but there were was significant buildup. Here I document how I fixed the problem by pulling the machine apart, cleaning it and replacing the rubber gaskets.
Шаг 1 Tools  ¶
Here are the tools you need (from left):
Шаг 1 Tools  ¶
  • Here are the tools you need (from left):
  • 1 flathead screwdriver
  • 2 allen keys / allen wrenches, one small, one larger
  • 13mm thin spanner / wrench
  • 2 #1 Philips head screw drivers (one short, one long).
  • One adjustable spanner / wrench
Шаг 2 Parts  ¶
Parts from coffeeparts.com (in 2009).  Today coffeeparts.com.au still sells parts for Gaggia Espresso machines, but I no longer live in Australia so I don't buy from them.
Шаг 2 Parts  ¶
  • Parts from coffeeparts.com (in 2009). Today coffeeparts.com.au still sells parts for Gaggia Espresso machines, but I no longer live in Australia so I don't buy from them.
Шаг 3  ¶
First, unplug the espresso machine's power cord.
Шаг 3  ¶
  • First, unplug the espresso machine's power cord.
  • The top of the machine is removed by removing two Phillips head screws (see the red arrows for the location).
  • Be careful - there is a ground wire running to the coffee cup warmer.
Шаг 4  ¶
The next step is to carefully remove the ground wire from the cup warmer.  Pull the metal clip, not the plastic wire cover.
Шаг 4  ¶
  • The next step is to carefully remove the ground wire from the cup warmer. Pull the metal clip, not the plastic wire cover.
  • You can now remove the top of the machine.
Шаг 5  ¶
The next steps are to disconnect the electrical connections (the wiring harness).
Шаг 5  ¶
  • The next steps are to disconnect the electrical connections (the wiring harness).
  • Start with the connections at the rear of the machine. The earth wire (yellow/green) is on the left.
  • Use a marker to label the two power wires - it will make it easier to reassemble later. Be sure to pull on the plastic clip rather than the cable.
Шаг 6  ¶
To remove the cables from the front switch, it's easier to start by pushing the switch through the front of the machine.
Шаг 6  ¶
  • To remove the cables from the front switch, it's easier to start by pushing the switch through the front of the machine.
  • Push on the clips on either side of the switch block and gently push it through.
Шаг 7  ¶
Make sure you label each connector.  It's possible to use the wiring diagram if you forget, but much easier if use labels.
Шаг 7  ¶
  • Make sure you label each connector. It's possible to use the wiring diagram if you forget, but much easier if use labels.
Шаг 8  ¶
There's an earth wire attached to the top of the pump that should be removed as well, marked with a red box in the picture.
Шаг 8  ¶
  • There's an earth wire attached to the top of the pump that should be removed as well, marked with a red box in the picture.
  • You DO NOT need to remove the heating unit connectors (two of them are marked with yellow boxes in the picture).
Шаг 9  ¶
It's a good idea to remove the shower screen now if you have not already done so.  It's held on by a single Philips head screw as shown.
Шаг 9  ¶
  • It's a good idea to remove the shower screen now if you have not already done so. It's held on by a single Philips head screw as shown.
  • If you have some descaler solution handy, leave the screw and the shower screen soaking in it while you work.
Шаг 10  ¶
Нет изображения
Шаг 10  ¶
  • Remove the pump assembly by releasing the two Philips head screws on either side of the pump. Move the pump to the right, out of the way, for the next step.
  • (TODO: photo)
Шаг 11  ¶
Now we disconnect the tubing that leads to the overflow pipe.  Locate the external overflow pipe connector.
Шаг 11  ¶
  • Now we disconnect the tubing that leads to the overflow pipe. Locate the external overflow pipe connector.
Шаг 12  ¶
Use a 13mm spanner / wrench to hold the inside part still while you loosen the external connector.
Шаг 12  ¶
  • Use a 13mm spanner / wrench to hold the inside part still while you loosen the external connector.
  • This step is much easier if you move the pump out of the way first (see step 9).
Шаг 13  ¶
Remove the milk frothing attachment by unscrewing the bolt that holds it in place.
Шаг 13  ¶
  • Remove the milk frothing attachment by unscrewing the bolt that holds it in place.
  • Gently pull the attachment away from the machine.
Шаг 14  ¶
Remove the four bolts holding the boiler assembly into the case of the machine.  You'll need the smaller of the allen keys / wrenches for this.  (the diagram only shows three of the bolts, the fourth is obscured).
Шаг 14  ¶
  • Remove the four bolts holding the boiler assembly into the case of the machine. You'll need the smaller of the allen keys / wrenches for this. (the diagram only shows three of the bolts, the fourth is obscured).
Шаг 15  ¶
Нет изображения
Шаг 15  ¶
  • Gently lift the pump and the boiler assembly out of the base of the machine. If anything is stuck, check the previous steps to make sure you didn't miss anything.
  • There may be some fluid draining from the boiler at this point, so make sure you are prepared for it!
