Помощь
Sony Xperia Z3 Compact Back Cover Replacement
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
Remove the back cover of the Sony Xperia Z3 Compact.
  • Автор: Sophia
  • Времени уйдёт: 10 - 45 мин.
  • Сложность: Средняя
Use this guide to remove the back cover of the Sony Xperia Z3 Compact.
Шаг 1 Heat the cover glue  ¶
Heat up along the edges of the cover to soften the glue.
  • Heat up along the edges of the cover to soften the glue.
  • Ideal temperature is around 120 - 150 °C for 60 seconds.
Шаг 2  ¶
Place a suction cup on the back cover and pull to open a gap.
Шаг 2  ¶
  • Place a suction cup on the back cover and pull to open a gap.
  • Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
Шаг 3  ¶
Finally, remove the back cover.
Шаг 3  ¶
  • Finally, remove the back cover.
  • Be careful, the back cover is fragile and can break.
  • It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
