Помощь
iPad Mini 3 Wi-Fi Headphone Jack Replacement
Replace the headphone jack in the iPad Mini 3.
Use this guide to replace the headphone jack in your iPad Mini 3.
Разделы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 Headphone Jack  ¶
Remove the single 4.4 mm Phillips #00 screw securing the headphone jack to the rear case.
  • Remove the single 4.4 mm Phillips #00 screw securing the headphone jack to the rear case.
Шаг 2  ¶
Slide the flat end of a spudger beneath the length of the headphone jack cable, separating the adhesive securing the cable to the rear case. Slide the flat end of a spudger beneath the length of the headphone jack cable, separating the adhesive securing the cable to the rear case.
Шаг 2  ¶
  • Slide the flat end of a spudger beneath the length of the headphone jack cable, separating the adhesive securing the cable to the rear case.
Шаг 3  ¶
Continue to carefully pry under the cable near the headphone jack. Continue to carefully pry under the cable near the headphone jack.
Шаг 3  ¶
  • Continue to carefully pry under the cable near the headphone jack.
Шаг 4  ¶
Pull the headphone jack straight out of its recess in the rear case. Pull the headphone jack straight out of its recess in the rear case.
Шаг 4  ¶
  • Pull the headphone jack straight out of its recess in the rear case.
