Помощь
iPod 1st Generation Battery Replacement
Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
  • Автор: iRobot
  • Времени уйдёт: 15 - 40 мин.
  • Сложность: Средняя
Battery not lasting long? Swap it out.
Разделы
Инструменты
Связанные запчасти
Шаг 1 Battery  ¶
Lift the battery up from the adhesive holding it to the iPod.
Шаг 1 Battery  ¶
  • Lift the battery up from the adhesive holding it to the iPod.
  • Lay the battery next to the iPod (it is still connected to the logic board).
Шаг 2  ¶
Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
Шаг 2  ¶
  • Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
Шаг 3  ¶
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Шаг 3  ¶
  • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
