Помощь
Nexus 9 Rear Facing Camera Replacement
Replace the rear-facing camera.
  • Автор: Sergio Vargas
  • Времени уйдёт: 15 - 20 мин.
  • Сложность: Средняя
Use this guide to replace the rear-facing camera on your Nexus 9.
Разделы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 Rear Facing Camera  ¶
Remove the three 3mm T5 Torx screws. Remove the five 2 mm Phillips #000 screws.
  • Remove the three 3mm T5 Torx screws.
  • Remove the five 2 mm Phillips #000 screws.
Шаг 2  ¶
Using your fingers, pull up on ribbon connector to expose another ribbon connector below. Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
Шаг 2  ¶
  • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
  • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
  • Pull up the ribbon connector with your fingers.
Шаг 3  ¶
With both ribbons out of the way, you can now lift the motherboard off of the tablet with your hand. The camera is attached to the back side of the motherboard via a ribbon cable.
Шаг 3  ¶
  • With both ribbons out of the way, you can now lift the motherboard off of the tablet with your hand.
  • The camera is attached to the back side of the motherboard via a ribbon cable.
  • Use a spudger or your fingernail to disconnect the camera from the motherboard.
  • There is a small board that comes off easily with the camera. It is attached to the camera with a ZIF connector, and will need to be swapped over to the replacement camera.
