Помощь
JVC Adixxion GC-XA1BU Zoom (+/-) Buttons Replacement
Нужны более качественные фото
Лучшие фотографии будут усовершенствовать руководство. Помоги нам, редактирую старые или сделай и загрузи новые!
Буллеты!
Буллеты!
Использование примечания и разного цвета шрифта, в частности использование нумерации, поможет сделать это руководство более понятным!
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
This guide will show you how to replace your camera's zoom (+/-) buttons.
To complete this guide, you will need to purchase a new zoom (+/-) button and make sure that you have the tools listed. It is always good practice to make sure that the device is completely powered off and remove the battery before attempting any repairs.
Разделы
Шаг 1 Zoom (+/-) Buttons  ¶
Remove the top two Phillips screws (4mm headsize x 3mm length). Now use the tweezers to gently grab and remove the silver metal plate that the screws were holding in place. Remove the top two Phillips screws (4mm headsize x 3mm length). Now use the tweezers to gently grab and remove the silver metal plate that the screws were holding in place.
  • Remove the top two Phillips screws (4mm headsize x 3mm length). Now use the tweezers to gently grab and remove the silver metal plate that the screws were holding in place.
Шаг 2  ¶
Remove the bottom two Phillips screws (4mm headsize x 3mm length).
Шаг 2  ¶
  • Remove the bottom two Phillips screws (4mm headsize x 3mm length).
Шаг 3  ¶
The zoom (+/-) buttons are attached to the red, black, and white threaded wire. Use the tweezers to gently pull on this wire and remove the zoom (+/-) buttons. The zoom (+/-) buttons are attached to the red, black, and white threaded wire. Use the tweezers to gently pull on this wire and remove the zoom (+/-) buttons.
Шаг 3  ¶
  • The zoom (+/-) buttons are attached to the red, black, and white threaded wire. Use the tweezers to gently pull on this wire and remove the zoom (+/-) buttons.
