Помощь
Gateway MD2614u Fan Replacement
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
This guide shows you how to remove the fan from your laptop.
  • Автор: Toni Pipes
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Средняя
You will remove the back cover, remove screws from the fan and heat sink, and take out the fan from the laptop.
Разделы
Инструменты
Шаг 1 Fan  ¶
Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
Шаг 1 Fan  ¶
  • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
  • Pull the plastic part of the cable, not the wires, so that the plug does not break.
Шаг 2  ¶
Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
Шаг 2  ¶
  • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
Шаг 3  ¶
The fan is permanently attached to the silver heat sink next to the RAM.
Шаг 3  ¶
  • The fan is permanently attached to the silver heat sink next to the RAM.
  • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
  • Take out the screws in the numerical order shown on the heat sink.
Шаг 4  ¶
Pull the fan and heat sink toward you at a 20 degree angle upward.
Шаг 4  ¶
  • Pull the fan and heat sink toward you at a 20 degree angle upward.
