Помощь
Motorola V557 Motherboard Replacement
Запутанный текст
Запутанный текст
Некоторые части этого руководства является запутанными, дублируются или не по теме. Отредактируй их!
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
This guide details the removal of the V557's motherboard.
  • Автор: Chad Brantley
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Средняя
The motherboard acts as the "brain" of the phone. Any damage the phone sustains to this region generally causes major malfunctions; thus, you should take extra care while removing/replacing this piece.
Разделы
Шаг 1 Motherboard  ¶
Separate the front ribbon cable from the board with a plastic opening tool. Separate the front ribbon cable from the board with a plastic opening tool. Separate the front ribbon cable from the board with a plastic opening tool.
Шаг 1 Motherboard  ¶
  • Separate the front ribbon cable from the board with a plastic opening tool.
Шаг 2  ¶
Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard. Lift out the motherboard only after all cables have been disconnected.  Try to touch it only from the sides. Lift out the motherboard only after all cables have been disconnected.  Try to touch it only from the sides.
Шаг 2  ¶
  • Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard.
  • Lift out the motherboard only after all cables have been disconnected. Try to touch it only from the sides.
