Помощь
Suzuki FA50 Moped Exhaust Pipe Replacement
Use this guide to remove the exhaust pipe from your Suzuki moped.
  • Автор: Miroslav Djuric
  • Времени уйдёт: 10 мин.
  • Сложность: Просто
Use this guide to remove the exhaust pipe from your Suzuki FA50 moped.
Шаг 1 Exhaust Pipe  ¶
Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
Шаг 2  ¶
There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
Шаг 2  ¶
  • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
  • Use a 10 mm socket wrench to unscrew the two hex nuts.
Шаг 3  ¶
Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
Шаг 3  ¶
  • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
  • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
