Помощь
Disassembling Fujifilm Endeavor 100ix Outer Casing
This guide will provide instructions on how to disassemble the Fujifilm Endeavor 100 ix camera.
  • Автор: Eric Nicolai
  • Времени уйдёт: 20 - 30 мин.
  • Сложность: Сложно
This guide will instruct camera owners how to take off the outer casing and how to access the inside components to repair and/or replace broken parts.
Инструменты
Шаг 1 Outer Casing  ¶
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Шаг 2  ¶
Locate the battery door.
Шаг 2  ¶
  • Locate the battery door.
Шаг 3  ¶
Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
Шаг 3  ¶
  • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
Шаг 4  ¶
Remove the battery from the camera by pulling the battery door outwards.
Шаг 4  ¶
  • Remove the battery from the camera by pulling the battery door outwards.
Шаг 5  ¶
Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
Шаг 5  ¶
  • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
Шаг 6  ¶
Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver. Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
Шаг 6  ¶
  • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
Шаг 7  ¶
Locate the film door latch located on the side of the camera.
Шаг 7  ¶
  • Locate the film door latch located on the side of the camera.
  • Insert the spudger under the latch.
  • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
  • Pry the latch upward, applying force perpendicular to the camera.
Шаг 8  ¶
Insert the flat edge of the spudger between the gold front casing and the black back casing.
Шаг 8  ¶
  • Insert the flat edge of the spudger between the gold front casing and the black back casing.
  • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
Шаг 9  ¶
Squeeze the camera by placing a thumb on the tab marked CE.
Шаг 9  ¶
  • Squeeze the camera by placing a thumb on the tab marked CE.
  • Pull the back half of the camera firmly away from the camera body.
Шаг 10  ¶
Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
Шаг 10  ¶
  • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
Шаг 11  ¶
Pull the front cover off of the camera by lifting the tripod tab over the tripod hole. Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Шаг 11  ¶
  • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
