Помощь
Samsung P241 Front Panel Replacement
This guide will show you how to remove the front panel of the DVD player to make further repairs.
  • Автор: Sarah Wachtfogel
  • Времени уйдёт: 5 мин.
  • Сложность: Средняя
Make sure you look at the Samsung P241 Troubleshooting Guide first to see if you can solve your problem without taking the DVD player apart.
Разделы
Инструменты
Шаг 1 Front Panel  ¶
With the front of the DVD player facing you, turn the power on and eject the disc tray. Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover.  The cover should easily pop up and off the disc tray.
Шаг 1 Front Panel  ¶
  • With the front of the DVD player facing you, turn the power on and eject the disc tray.
  • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
  • Be careful not to crack or bend the disc tray by pulling too hard.
Шаг 2  ¶
To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player. Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off. If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
Шаг 2  ¶
  • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
  • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
  • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
Шаг 3  ¶
Gently remove the front panel by pulling it forward.
Шаг 3  ¶
  • Gently remove the front panel by pulling it forward.
Шаг 4  ¶
Press the eject button again to make the disc tray slide back into place.
Шаг 4  ¶
  • Press the eject button again to make the disc tray slide back into place.
  • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
