Помощь
Nintendo DS Lite Lower Case Replacement
Nintendo DS Lite lower case replacement.
  • Автор: Matthew Newsom
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
Replace your Nintendo DS Lite lower case to make it look straight-from-the-store new!
Разделы
Инструменты
Шаг 1 Lower Case  ¶
Use the tip of a spudger to pry both rubber feet off the DS Lite. Use the tip of a spudger to pry both rubber feet off the DS Lite.
Шаг 1 Lower Case  ¶
  • Use the tip of a spudger to pry both rubber feet off the DS Lite.
Шаг 2  ¶
Remove the following screws securing the lower case to the body of the DS Lite:
Шаг 2  ¶
  • Remove the following screws securing the lower case to the body of the DS Lite:
  • Two 4.3 mm gold Phillips screws
  • One 3.9 mm black Tri-Wing screw
  • One 3.3 mm silver Phillips screw
  • Three 5.5 mm silver Tri-Wing screws
Шаг 3  ¶
Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite. Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process. Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Шаг 3  ¶
  • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
  • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Шаг 4  ¶
Lift the lower case away from the rest of the DS Lite.
Шаг 4  ¶
  • Lift the lower case away from the rest of the DS Lite.
  • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
