Помощь
Samsung SGH-E317 Camera Replacement
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
Отсутствуют необходимые  руководства
В этом руководстве не хватает информации о том, как начать процесс. Сделай необходимое руководство!
Replacement of camera on the front panel of cell phone.
  • Автор: Michael Strange
  • Времени уйдёт: 15 - 30 мин.
  • Сложность: Средняя
Items needed:
You will need a wedge shaped tool in order to pry open the front panel of cell phone and a screwdriver.
Шаг 1 Camera  ¶
Remove the plastic coverings at the base of the LCD screen using your fingers. Remove the plastic coverings at the base of the LCD screen using your fingers.
Шаг 1 Camera  ¶
  • Remove the plastic coverings at the base of the LCD screen using your fingers.
Шаг 2  ¶
Remove the two 4.5mm screws located underneath the plastic coverings.
Шаг 2  ¶
  • Remove the two 4.5mm screws located underneath the plastic coverings.
  • You may want to use tweezers to remove the loosened screws.
Шаг 3  ¶
Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
Шаг 3  ¶
  • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
  • Gently pry the top panel off around the entire frame.
Шаг 4  ¶
Make sure that the top panel is completely separated from the LCD display around the entire perimeter. Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
Шаг 4  ¶
  • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
Шаг 5  ¶
Remove the top panel.
Шаг 5  ¶
  • Remove the top panel.
Шаг 6  ¶
Detach the connecting wire panel from the LCD display system. Detach the connecting wire panel from the LCD display system.
Шаг 6  ¶
  • Detach the connecting wire panel from the LCD display system.
Шаг 7  ¶
Using tweezers, remove the camera from the cellphone casing. Using tweezers, remove the camera from the cellphone casing.
Шаг 7  ¶
  • Using tweezers, remove the camera from the cellphone casing.
