Помощь
Canon PowerShot S410 Back Cover Replacement
Removing and replacing a damaged or worn back cover.
  • Автор: Randy Lormand
  • Времени уйдёт: 4 - 5 мин.
  • Сложность: Просто
This guide demonstrates how to remove the cameras back panel for cleaning or replacement.
Разделы
Инструменты
Шаг 1 Back Cover  ¶
Start by laying the camera flat with the LCD screen facing up.
Шаг 1 Back Cover  ¶
  • Start by laying the camera flat with the LCD screen facing up.
  • Remove the 3.8mm screw in the upper right corner.
Шаг 2  ¶
Position the camera with the bottom facing up.
Шаг 2  ¶
  • Position the camera with the bottom facing up.
  • Remove the 4.8mm screw.
  • Remove the two 2.3mm screws.
Шаг 3  ¶
Position the camera so that the rubber "AV Out Digital" tab is facing upward. Slide this rubber tab out of the way to reveal the bottom screw.
Шаг 3  ¶
  • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
  • Slide this rubber tab out of the way to reveal the bottom screw.
  • Remove the two 3.7mm screws.
Шаг 4  ¶
Turn the camera with the back side facing you.
Шаг 4  ¶
  • Turn the camera with the back side facing you.
  • Grip the edges of the back plate, and carefully slide it off.
  • If there is any resistance in movement, double check there are no screws left in the chassis.
