Помощь
Canon PowerShot S410 LCD Screen Replacement
Запутанный текст
Запутанный текст
Некоторые части этого руководства является запутанными, дублируются или не по теме. Отредактируй их!
This repair guide will help you install a broken LCD in your Canon PowerShot S410.
  • Автор: kubayubay
  • Времени уйдёт: 20 - 25 мин.
  • Сложность: Сложно
This installation guide will help you remove your broken LCD and install in a new replacement.
Разделы
Инструменты
Шаг 1 LCD Screen  ¶
Position the camera so that the motherboard is facing you. Remove the plastic flap covering the motherboard.
Шаг 1 LCD Screen  ¶
  • Position the camera so that the motherboard is facing you.
  • Remove the plastic flap covering the motherboard.
  • Using your fingernail, open the black clip holding the ribbon cable.
  • Grab the ribbon cable and carefully pull it out of slot.
Шаг 2  ¶
Turn the camera so that the bottom side is facing you. Remove the 2.1mm screw.
Шаг 2  ¶
  • Turn the camera so that the bottom side is facing you.
  • Remove the 2.1mm screw.
  • Grab the sides of the bottom panel and lift it up to expose the ribbon cable.
Шаг 3  ¶
Turn the camera so that the motherboard is facing you. Using your fingernail, open the black clip holding the ribbon cable.
Шаг 3  ¶
  • Turn the camera so that the motherboard is facing you.
Шаг 4  ¶
Turn the camera so that the LCD screen is facing you.
Шаг 4  ¶
  • Turn the camera so that the LCD screen is facing you.
  • Remove the two 2.1mm screws on the aluminum tabs of the LCD screen.
Шаг 5  ¶
Using a pair of tweezers, carefully pull the top ribbon cable out of the slot. Grasp sides of LCD screen and lift off of camera.
Шаг 5  ¶
  • Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
  • Grasp sides of LCD screen and lift off of camera.
