Помощь
iPhone 4 Verizon Headphone Jack Cable Replacement
Replace a broken headphone jack cable that contains the upper microphone as well as the electronic portions of the volume buttons and silent switch on your Verizon iPhone 4.
Use this guide to replace the headphone jack cable which also contains the upper microphone and electronic portions of the volume buttons and silent switch.
Разделы
Шаг 1 Headphone Jack Cable  ¶
Remove the four 1.6 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
  • Remove the four 1.6 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
Шаг 2  ¶
Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
Шаг 2  ¶
  • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
Шаг 3  ¶
Gently pull the silent switch bracket away from the outer case and peel its small ribbon cable off the inside of the iPhone.
Шаг 3  ¶
  • Gently pull the silent switch bracket away from the outer case and peel its small ribbon cable off the inside of the iPhone.
Шаг 4  ¶
Remove the headphone jack cable from the iPhone.
Шаг 4  ¶
  • Remove the headphone jack cable from the iPhone.
Шаг 5  ¶
If you are replacing the headphone jack cable, use the edge of a plastic opening tool to remove the steel brackets for the volume buttons and the silent switch. Transfer these steel brackets to the new headphone jack cable. Transfer these steel brackets to the new headphone jack cable.
Шаг 5  ¶
  • If you are replacing the headphone jack cable, use the edge of a plastic opening tool to remove the steel brackets for the volume buttons and the silent switch.
  • Transfer these steel brackets to the new headphone jack cable.
