Помощь
MacBook Core 2 Duo Upper Case Replacement
Replace your MacBook Core 2 Duo's upper case to gain a new keyboard and trackpad.
  • Автор: iRobot
  • Времени уйдёт: 45 мин. - 2 часов
  • Сложность: Средняя
Changing the top case will also give you a new trackpad and keyboard.
Note: the ribbon cable is fragile but replaceable, it is connected with a ZIF socket under the touchpad.
Шаг 1 Upper Case  ¶
Remove the following 3 screws:
Шаг 1 Upper Case  ¶
  • Remove the following 3 screws:
  • One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
  • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
  • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  • The shorter of the three screws goes in the middle.
Шаг 2  ¶
Remove the following 3 screws from the rear wall of the battery compartment:
Шаг 2  ¶
  • Remove the following 3 screws from the rear wall of the battery compartment:
  • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
  • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  • Take extra caution with these screws as they can strip easily.
Шаг 3  ¶
Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Шаг 3  ¶
  • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
Шаг 4  ¶
Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
Шаг 4  ¶
  • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
Шаг 5  ¶
Remove the following 4 screws from the back of the computer:
Шаг 5  ¶
  • Remove the following 4 screws from the back of the computer:
  • The longer screws go on the inside, shorter screws on the outside.
  • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
  • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Шаг 6  ¶
Remove the two Phillips screws from the optical drive side of the computer.
Шаг 6  ¶
  • Remove the two Phillips screws from the optical drive side of the computer.
  • Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
  • It is not necessary to remove the similar screws on the other side of the computer.
Шаг 7  ¶
There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
Шаг 7  ¶
  • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
  • Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
  • The upper case is likely to stick at the connection above the optical drive. If this is the case, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening.
  • If you stand the base on end to get a better look you may displace the total of 4 grey plastic clips that hold the keyboard in place. Don't panic. They slide into slots at the top right-most edge near the CD drive.
Шаг 8  ¶
While holding up the upper case, pull up the black tab of the silver cable away from its connector. If there is no black tab, you can also use a spudger to gently pry the connector from its housing.  This connector is tall, so be sure to pry straight up. If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
Шаг 8  ¶
  • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
  • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  • While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
  • Upon reassembly, there are 4 grey plastic clips on the optical drive side of the keyboard (refer to second picture). They must be installed in their slots for the keyboard to snap in properly.
  • To make the reassamble process easier, it's better to pull out the clips first by pulling it straight up gently. Be careful not to put too much strength because it will break.
