Помощь
HP Pavilion zd8000 Screen Replacement
  • Автор: Allie Menard
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
Разделы
Шаг 1 Screen  ¶
Close the lid and rotate the laptop so that the vents are facing you. Unscrew the two 8mm Philips screws below the hinges.
Шаг 1 Screen  ¶
  • Close the lid and rotate the laptop so that the vents are facing you.
  • Unscrew the two 8mm Philips screws below the hinges.
Шаг 2  ¶
Carefully rotate the laptop 90 degrees counter-clockwise and open the screen. Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
Шаг 2  ¶
  • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
  • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
Шаг 3  ¶
Using tweezers, remove the black cable from the hole leading to the WiFi enclosure. Pull gently to remove the black and grey cables from the case.
Шаг 3  ¶
  • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
  • Pull gently to remove the black and grey cables from the case.
  • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
Шаг 4  ¶
Using tweezers, pull the black cable towards the display and through the hole in the casing. Using tweezers, pull the black cable towards the display and through the hole in the casing.
Шаг 4  ¶
  • Using tweezers, pull the black cable towards the display and through the hole in the casing.
Шаг 5  ¶
Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display. Lift the screen upwards to detach it from the laptop. Lift the screen upwards to detach it from the laptop.
Шаг 5  ¶
  • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
  • Lift the screen upwards to detach it from the laptop.
