Помощь
HP Pavilion zd8000 Motherboard Replacement
Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
  • Автор: Allie Menard
  • Времени уйдёт: 30 - 40 мин.
  • Сложность: Средняя
Разделы
Шаг 1 Motherboard  ¶
Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon. Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
Шаг 1 Motherboard  ¶
  • Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
Шаг 2  ¶
Unscrew and remove the two 8mm Philips screws from the heat sink fan.
Шаг 2  ¶
  • Unscrew and remove the two 8mm Philips screws from the heat sink fan.
Шаг 3  ¶
Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
Шаг 3  ¶
  • Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
  • Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
Шаг 4  ¶
Using tweezers, remove the left speaker cable by pulling the white connector towards you. Using tweezers, remove the left speaker cable by pulling the white connector towards you.
Шаг 4  ¶
  • Using tweezers, remove the left speaker cable by pulling the white connector towards you.
Шаг 5  ¶
Remove the LED board cable by pulling the white tab towards you. Remove the LED board cable by pulling the white tab towards you.
Шаг 5  ¶
  • Remove the LED board cable by pulling the white tab towards you.
Шаг 6  ¶
Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you. Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
Шаг 6  ¶
  • Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
Шаг 7  ¶
Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard. Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you. Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
Шаг 7  ¶
  • Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard.
  • Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
Шаг 8  ¶
Using tweezers, pull up on the Bluetooth module to remove it. Using tweezers, pull up on the Bluetooth module to remove it.
Шаг 8  ¶
  • Using tweezers, pull up on the Bluetooth module to remove it.
Шаг 9  ¶
Remove the fan cable by pulling the white connector away from you. Remove the fan cable by pulling the white connector away from you.
Шаг 9  ¶
  • Remove the fan cable by pulling the white connector away from you.
Шаг 10  ¶
Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector. Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
Шаг 10  ¶
  • Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
Шаг 11  ¶
Carefully flip the laptop face-down with the battery compartment facing you. Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
Шаг 11  ¶
  • Carefully flip the laptop face-down with the battery compartment facing you.
  • Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
Шаг 12  ¶
Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you. Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
Шаг 12  ¶
  • Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you.
  • Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
Шаг 13  ¶
Locate the PC card below the SD card reader. Push the button to its left once to eject the button itself, then press it once again to remove the PC card. Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
Шаг 13  ¶
  • Locate the PC card below the SD card reader.
  • Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
Шаг 14  ¶
Once the PC card pops out, pull it out.
Шаг 14  ¶
  • Once the PC card pops out, pull it out.
Шаг 15  ¶
Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard. Push in the grey button to the left of the PC card as far as possible.
Шаг 15  ¶
  • Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard.
  • Push in the grey button to the left of the PC card as far as possible.
  • Keeping the button pressed down, lift the motherboard up until the button pops out the top of the case.
Шаг 16  ¶
Pull the right casing to the side to release the ports on the motherboard from it.
Шаг 16  ¶
  • Pull the right casing to the side to release the ports on the motherboard from it.
Шаг 17  ¶
Lift the motherboard up until it releases from the bottom casing and remove it from the laptop. Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
Шаг 17  ¶
  • Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
