Помощь
HTC SMT 6175 Battery Replacement
Taking out the phone's battery.
  • Автор: Luke Plewa
  • Времени уйдёт: 10 - 15 секунд
  • Сложность: Очень просто
Removing the battery is an essential step in opening up the phone.
Шаг 1 Back Case  ¶
First, flip the phone over so that the back is facing you.
Шаг 1 Back Case  ¶
  • First, flip the phone over so that the back is facing you.
Шаг 2  ¶
Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone. Set this piece aside until you need to   reassemble the phone.
Шаг 2  ¶
  • Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone.
  • Set this piece aside until you need to reassemble the phone.
Шаг 3 Battery  ¶
Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
Шаг 3 Battery  ¶
  • Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
