Помощь
Dell Studio 15 Keyboard Replacement
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
Here I will show you how to properly remove the keyboard from your Dell Studio 15 laptop, as well as install a new one.
  • Автор: Eric Bentley
  • Времени уйдёт: 10 мин.
  • Сложность: Просто
Installing a new keyboard in your Dell Studio laptop is easier than you might think, it just involves some basic screw removal and knowledge. This guide can also be used to simply fix an existing keyboard that may be malfunctioning.
Шаг 1 Keyboard  ¶
Gather materials and tools Flip laptop over Remove battery and power cord before doing anything
Шаг 1 Keyboard  ¶
  • Gather materials and tools
  • Flip laptop over
  • Remove battery and power cord before doing anything
Шаг 2  ¶
Where the battery was, take out the two screws with the letter "K" next to them Save the screws somewhere safe, and flip the laptop rightside up
Шаг 2  ¶
  • Where the battery was, take out the two screws with the letter "K" next to them
  • Save the screws somewhere safe, and flip the laptop rightside up
Шаг 3  ¶
Open the laptop Take the flathead screwdriver, and put it under the bezel that goes around the keyboard If you're simply fixing the existing keyboard, be careful not to pry a key off. They are close to impossible to get back on
Шаг 3  ¶
  • Open the laptop
  • Take the flathead screwdriver, and put it under the bezel that goes around the keyboard
  • If you're simply fixing the existing keyboard, be careful not to pry a key off. They are close to impossible to get back on
  • Pry the bezel out of the frame. It might take some effort, but this is the correct method
  • Once one part has snapped out of the frame, continue to carefully remove the rest of the bezel
Шаг 4  ¶
Once the bezel is removed, put the screwdriver under the media control bar Continue to apply pressure, prying it out of place; it should snap out easy Do not rip it out without precaution. It's attached with a delicate ribbon cable, and if damaged, you'll be replacing more than the keyboard
Шаг 4  ¶
  • Once the bezel is removed, put the screwdriver under the media control bar
  • Continue to apply pressure, prying it out of place; it should snap out easy
  • Do not rip it out without precaution. It's attached with a delicate ribbon cable, and if damaged, you'll be replacing more than the keyboard
  • Once snapped out of it's place, flip it over gently onto the keyboard
Шаг 5  ¶
Unscrew the two screws at the top of the keyboard using the Phillips screwdriver Set the screws aside along with the other ones. They are the same size, no need to worry about getting them mixed up
Шаг 5  ¶
  • Unscrew the two screws at the top of the keyboard using the Phillips screwdriver
  • Set the screws aside along with the other ones. They are the same size, no need to worry about getting them mixed up
Шаг 6  ¶
Now that the screws are out, lift the top of the keyboard You will notice some resistance due to clips on the sides. Lift the side of the keyboard gently, taking the board out of the clip without breaking it Once both sides are out of the clips, slide the keyboard forward a bit
Шаг 6  ¶
  • Now that the screws are out, lift the top of the keyboard
  • You will notice some resistance due to clips on the sides. Lift the side of the keyboard gently, taking the board out of the clip without breaking it
  • Once both sides are out of the clips, slide the keyboard forward a bit
  • Flip the keyboard over, minding the ribbon cable, over onto the palmrest
Шаг 7  ¶
Now that they physical keyboard is removed, we can focus on the ribbon cable Caution, this step can make or break the connection point, so be gentle Gently flip the black hatch part of the connection point upwards
Шаг 7  ¶
  • Now that they physical keyboard is removed, we can focus on the ribbon cable
  • Caution, this step can make or break the connection point, so be gentle
  • Gently flip the black hatch part of the connection point upwards
  • Remove the ribbon cable from the connection point
  • When re-installing the cable, be sure that it is inserted all the way, and that the hatch is closed. If not, it may malfunction, or not work at all, and you will have to do this all over again
Шаг 8  ¶
Congratulations, you've successfully removed the keyboard! Congratulations, you've successfully removed the keyboard!
Шаг 8  ¶
  • Congratulations, you've successfully removed the keyboard!
