Помощь
Canon Powershot S200 Motherboard Replacement
Нужны более качественные фото
Лучшие фотографии будут усовершенствовать руководство. Помоги нам, редактирую старые или сделай и загрузи новые!
Буллеты!
Буллеты!
Использование примечания и разного цвета шрифта, в частности использование нумерации, поможет сделать это руководство более понятным!
This guide shows one how to install a new motherboard into the device.
  • Автор: Orlando Zuniga
  • Времени уйдёт: 20 - 25 мин.
  • Сложность: Средняя
The motherboard controls the operations of the camera. Damage to the motherboard requires an entirely new motherboard.
Разделы
Инструменты
Шаг 1 Motherboard  ¶
Remove the lanyard.
Шаг 1 Motherboard  ¶
  • Remove the lanyard.
Шаг 2  ¶
Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
Шаг 2  ¶
  • Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Be careful to keep track of the different screw sizes as you proceed with this guide.
Шаг 3  ¶
Remove the single 3.8mm screw from the back face of the camera.
Шаг 3  ¶
  • Remove the single 3.8mm screw from the back face of the camera.
Шаг 4  ¶
Remove the two 2.3mm screws from the right face of the camera.
Шаг 4  ¶
  • Remove the two 2.3mm screws from the right face of the camera.
Шаг 5  ¶
Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
Шаг 5  ¶
  • Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
Шаг 6  ¶
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Шаг 6  ¶
  • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Шаг 7  ¶
Remove the CF card door from the left side of the camera body. Remove the CF card door from the left side of the camera body.
Шаг 7  ¶
  • Remove the CF card door from the left side of the camera body.
Шаг 8  ¶
Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate. Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
Шаг 8  ¶
  • Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
Шаг 9  ¶
Remove the front face by sliding it off.
Шаг 9  ¶
  • Remove the front face by sliding it off.
Шаг 10  ¶
Remove the rubber seal that goes over the right side of the viewfinder.
Шаг 10  ¶
  • Remove the rubber seal that goes over the right side of the viewfinder.
Шаг 11  ¶
Remove the two 3.9mm screws that retain the laminated cooper sheet.
Шаг 11  ¶
  • Remove the two 3.9mm screws that retain the laminated cooper sheet.
Шаг 12  ¶
Remove the seven wire connections that connect to the motherboard. Remove the seven wire connections that connect to the motherboard.
Шаг 12  ¶
  • Remove the seven wire connections that connect to the motherboard.
Шаг 13  ¶
Remove the single 3.8mm screw that is on the motherboard.
Шаг 13  ¶
  • Remove the single 3.8mm screw that is on the motherboard.
Шаг 14  ¶
Carefully remove the motherboard from the main frame of the camera body.
Шаг 14  ¶
  • Carefully remove the motherboard from the main frame of the camera body.
