Помощь
iMac Intel 21.5" EMC 2428 Power Supply Replacement
Потенциальная опасность
При несоблюдении этих указаний техники безопасности, может возникнуть травма. Будьте внимательны и следуйте всем указаниям.
Replace the power supply in your iMac Intel 21.5" EMC 2428.
  • Автор: Walter Galan
  • Сложность: Средняя
Use this guide to replace a faulty power supply.
Разделы
Инструменты
Связанные запчасти
Шаг 1 Power Supply  ¶
The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
  • The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
  • Remove the following four screws securing the power supply to the outer case:
  • One 9.3 mm T10 coarse-threaded screw
  • One 25 mm T10 coarse-threaded screw
  • Two 22 mm T10 fine-threaded screws
Шаг 2  ¶
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Шаг 2  ¶
  • Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Шаг 3  ¶
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out and AC-In cables still attaching it to the iMac. Disconnect the DC-Out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Шаг 3  ¶
  • Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out and AC-In cables still attaching it to the iMac.
  • Disconnect the DC-Out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
  • Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
Шаг 4  ¶
Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
Шаг 4  ¶
  • Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
  • Remove the power supply from the outer case.
