Помощь
Asus ZenFone 2 Battery Replacement
Неправильные инструменты
Помогите улучшить эту инструкцию — пусть в кадре и в тексте будут правильные инструменты.
If your battery is defective, this replacement guide will allow you to replace your battery.
  • Автор: Eduardo Nodarse
  • Времени уйдёт: 20 мин.
  • Сложность: Сложно
Replacing the battery will require a good amount of work and time. Before you are able to get to the battery, you will first have to remove the bottom antennae.
Разделы
Инструменты
Связанные запчасти
Шаг 1 Battery  ¶
Use a plastic prying tool to carefully detach the bottom part of the antenna.
Шаг 1 Battery  ¶
  • Use a plastic prying tool to carefully detach the bottom part of the antenna.
  • The antenna can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
Шаг 2  ¶
Using the plastic opening tool, unlock the ribbon cable indicated in the picture by prying up the yellow tab. Using the plastic opening tool, unlock the ribbon cable indicated in the picture by prying up the yellow tab.
Шаг 2  ¶
  • Using the plastic opening tool, unlock the ribbon cable indicated in the picture by prying up the yellow tab.
Шаг 3  ¶
Using a plastic opening tool, remove the vibration motor from its housing.
Шаг 3  ¶
  • Using a plastic opening tool, remove the vibration motor from its housing.
Шаг 4  ¶
Gently remove the board from the phone using your hand.
Шаг 4  ¶
  • Gently remove the board from the phone using your hand.
Шаг 5  ¶
Using the plastic opening tool, gently pry  the ribbon cables up as indicated in the pictures. Using the plastic opening tool, gently pry  the ribbon cables up as indicated in the pictures.
Шаг 5  ¶
  • Using the plastic opening tool, gently pry the ribbon cables up as indicated in the pictures.
Шаг 6  ¶
Carefully remove the battery pack from the phone using your hand.
Шаг 6  ¶
  • Carefully remove the battery pack from the phone using your hand.
  • There are fragile tabs on the left and right side of the battery, be careful not to break them off.
Шаг 7  ¶
Carefully insert the metal spudger between  the battery and its metal housing and then slowly pry the two apart. Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone. Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone.
Шаг 7  ¶
  • Carefully insert the metal spudger between the battery and its metal housing and then slowly pry the two apart.
  • Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone.
