Помощь
Asus ZenFone 2 Display Replacement
Replace your display if it isn't functioning correctly or if it is cracked or broken.
  • Автор: Jessica Nguyen
  • Времени уйдёт: 25 - 30 мин.
  • Сложность: Очень сложно
Replacing the display will take patience and time as you will have to heat up the display to detach it from the adhesive sticking it to its housing. You will also have to unplug the entire antenna, take out the battery, and motherboard before being able to get to the display.
Разделы
Шаг 1 Display  ¶
Using the plastic opening tool, pry the display cable from the body of the phone. Using the plastic opening tool, pry the display cable from the body of the phone.
Шаг 1 Display  ¶
  • Using the plastic opening tool, pry the display cable from the body of the phone.
Шаг 2  ¶
Using a hair dryer or a heat gun, heat up the adhesive that attaches the display to the housing. The adhesive lies around the edges of the display.
Шаг 2  ¶
  • Using a hair dryer or a heat gun, heat up the adhesive that attaches the display to the housing. The adhesive lies around the edges of the display.
  • Using a heat gun will allow you to melt the adhesive in about 30 seconds; whereas a hair dryer will take about 3-5 minutes to melt the adhesive.
Шаг 3  ¶
Using the plastic opening tool, pry off the display by inserting the tool in between the display and the housing at the edges of the phone. Once the screen comes away from the backing, gently slide the opening tool around the edges while prying the rest of the screen away.
Шаг 3  ¶
  • Using the plastic opening tool, pry off the display by inserting the tool in between the display and the housing at the edges of the phone.
  • Once the screen comes away from the backing, gently slide the opening tool around the edges while prying the rest of the screen away.
  • Be careful not to bend the screen too much, or it might break.
Шаг 4  ¶
Once the screen has been separated from the backing, remove the display cable out of the hole in the top of the phone body.
Шаг 4  ¶
  • Once the screen has been separated from the backing, remove the display cable out of the hole in the top of the phone body.
  • You don't need to be careful removing this cable because it will be replaced by a new cable along with the new display. If you want to save it, rotate the display as you separate the display from the backing.
Шаг 5  ¶
Using a plastic opening tool, remove the speaker grill from the display. Place it in its designated spot on the body of the phone. We recommend attaching  the speaker grill to the actual body of the phone rather than the display.
Шаг 5  ¶
  • Using a plastic opening tool, remove the speaker grill from the display.
  • Place it in its designated spot on the body of the phone.
  • We recommend attaching the speaker grill to the actual body of the phone rather than the display.
Шаг 6  ¶
Carefully feed the antenna cables of the new display through the appropriate holes in the housing.
Шаг 6  ¶
  • Carefully feed the antenna cables of the new display through the appropriate holes in the housing.
  • Reattach the phone display with adhesive. You can either use the old adhesive (if it is in good enough condition), or newly purchased adhesive (2 mm thick, double sided).
