Помощь
Motorola RAZR V3i Battery Replacement
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
Using this guide, you will be able to install a replacement battery for your Motorola RAZR V3i.
  • Автор: Nigel
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
Связанные запчасти
Шаг 1 Battery  ¶
Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
Шаг 1 Battery  ¶
  • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
  • If you have a phone case, it has to be removed.
Шаг 2  ¶
Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge. Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely. The flat edge of a credit card or other flat object will also work.
Шаг 2  ¶
  • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
  • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
  • The flat edge of a credit card or other flat object will also work.
Шаг 3  ¶
Remove the battery by pushing down on it from the top while gently pulling it outwards. Be careful not to use too much force as the battery retaining tab could be damaged. Be careful not to use too much force as the battery retaining tab could be damaged.
Шаг 3  ¶
  • Remove the battery by pushing down on it from the top while gently pulling it outwards.
  • Be careful not to use too much force as the battery retaining tab could be damaged.
