Помощь
HTC Maple 100 Motherboard Replacement
Отсутствуют необходимые  руководства
В этом руководстве не хватает информации о том, как начать процесс. Сделай необходимое руководство!
Запутанный текст
Запутанный текст
Некоторые части этого руководства является запутанными, дублируются или не по теме. Отредактируй их!
After removing the battery and the backpanel
  • Автор: Andrew Van Meter
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
Be cautious about the ribbon cable
Разделы
Шаг 1 Motherboard  ¶
Remove the one 3.3mm #00 screw. Remove the one 3.3mm #00 screw.
Шаг 1 Motherboard  ¶
  • Remove the one 3.3mm #00 screw.
Шаг 2  ¶
Use your finger or the plastic opening tool to unclip the board. Be aware of the ribbon cable connected to the motherboard inside the phone.
Шаг 2  ¶
  • Use your finger or the plastic opening tool to unclip the board.
  • Be aware of the ribbon cable connected to the motherboard inside the phone.
Шаг 3  ¶
Peel off the yellow piece of tape from the phone Peel off the yellow piece of tape from the phone
Шаг 3  ¶
  • Peel off the yellow piece of tape from the phone
Шаг 4  ¶
First flip up the retaining flap with your fingernail or a plastic opening tool. Pull on the ribbon cable gently with your fingers Pull on the ribbon cable gently with your fingers
Шаг 4  ¶
  • First flip up the retaining flap with your fingernail or a plastic opening tool.
  • Pull on the ribbon cable gently with your fingers
Шаг 5  ¶
Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
Шаг 5  ¶
  • Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
Шаг 6  ¶
Gently pull on the ribbon cable to separate the motherboard. Gently pull on the ribbon cable to separate the motherboard.
Шаг 6  ¶
  • Gently pull on the ribbon cable to separate the motherboard.
