Помощь
iBook G4 12" 1.33 GHz Keyboard Replacement
Replacing this keyboard is easy and takes only a few minutes.
Разделы
Файлы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 Keyboard  ¶
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Шаг 1 Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Шаг 2  ¶
Remove the four silver Phillips screws that secure the RAM shield.
Шаг 2  ¶
  • Remove the four silver Phillips screws that secure the RAM shield.
Шаг 3  ¶
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Шаг 3  ¶
  • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
  • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
