Помощь
Huawei P9 Headphone Jack Replacement
Replace the headphone jack in your Huawei P9 smartphone.
  • Автор: Tobias Isakeit
  • Времени уйдёт: 25 мин.
  • Сложность: Средняя
Use this guide to replace the headphone jack in your Huawei P9 smartphone.
Разделы
Инструменты
Шаг 1 Headphone Jack  ¶
Remove the water indicator on top of the screw. Undo the two Phillips #00 screws. Remove metal bracket (mind the adhesive underneath).
  • Remove the water indicator on top of the screw.
  • Undo the two Phillips #00 screws.
  • Remove metal bracket (mind the adhesive underneath).
Шаг 2  ¶
Disconnect the flex cable and remove the headphone jack. The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
Шаг 2  ¶
  • Disconnect the flex cable and remove the headphone jack.
  • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
