Помощь
ASUS Eee PC 1018P RAM Replacement
Removal of the RAM.
  • Автор: Patrick Hallahan
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Просто
This guide outlines the removal of the RAM for repair or replacement.
Разделы
Инструменты
Связанные запчасти
Шаг 1 RAM  ¶
With the battery removed, locate the RAM cover.
Шаг 1 RAM  ¶
  • With the battery removed, locate the RAM cover.
Шаг 2  ¶
Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free. With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
Шаг 2  ¶
  • Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free.
  • With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
Шаг 3  ¶
Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module. In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
Шаг 3  ¶
  • Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module.
  • In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
  • The RAM module will pop upward at a slight angle when both tabs are detached.
Шаг 4  ¶
Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil. Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
Шаг 4  ¶
  • Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil.
  • Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
Шаг 5  ¶
Remove RAM module entirely for repair or replacement.
Шаг 5  ¶
  • Remove RAM module entirely for repair or replacement.
