Помощь
Техника: LG Gram 15" Repairability Assessment
Repairability assessment for the LG Gram 15" performed on January 6, 2017.
We disassembled the LG Gram 15" to see how the Surface/MacBook competitor stacks up.
Шаг 1 LG Gram 15" Repairability Assessment  ¶
Reference shot with packaging.
  • Reference shot with packaging.
Шаг 2  ¶
Reference shots. Reference shots. Reference shots.
Шаг 2  ¶
  • Reference shots.
Шаг 3  ¶
We first use tweezers to remove the three plastic screw covers and five rubber bumpers. We find eight Phillips screws holding the case together. After removing the screws, we use picks to remove the lower case which is held in with clips.
Шаг 3  ¶
  • We first use tweezers to remove the three plastic screw covers and five rubber bumpers.
  • We find eight Phillips screws holding the case together.
  • After removing the screws, we use picks to remove the lower case which is held in with clips.
Шаг 4  ¶
Lower case is removed to view the internals.
Шаг 4  ¶
  • Lower case is removed to view the internals.
Шаг 5  ¶
Battery comes out easily—just 6 screws and a connector on the motherboard. SSD is standard and user-upgradable. RAM is also standard and user-upgradable.
Шаг 5  ¶
  • Battery comes out easily—just 6 screws and a connector on the motherboard.
  • SSD is standard and user-upgradable.
  • RAM is also standard and user-upgradable.
  • At this time, it's cool to note that you can remove the display assembly, speakers, daughterboard, backup battery, motherboard, trackpad, and the fan.
  • Perhaps slightly more useful knowledge: The only component we cannot remove is the keyboard.
Шаг 6  ¶
We chose the fan + heatpipe combo. 7 screws and 1 plug Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card. There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
Шаг 6  ¶
  • We chose the fan + heatpipe combo. 7 screws and 1 plug
  • Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card.
  • There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
  • Trackpad's next. It's held in with 4 screws and pops out the top of the lower case.
Шаг 7  ¶
I/O board, wireless card, speakers, and CMOS battery. The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
Шаг 7  ¶
  • I/O board, wireless card, speakers, and CMOS battery.
  • The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
Шаг 8  ¶
Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
Шаг 8  ¶
  • Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film.
  • It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
Шаг 9  ¶
Four screws later, the display assembly is free from the lower case.
Шаг 9  ¶
  • Four screws later, the display assembly is free from the lower case.
Шаг 10  ¶
The LG Gram 15&quot; earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): Most components are immediately accessible after removing the lower case cover.
Шаг 10  ¶
  • The LG Gram 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
  • Most components are immediately accessible after removing the lower case cover.
  • RAM and SSD are user-replaceable and parts for upgrades are readily accessible.
  • Battery is also user-replaceable.
  • Only Phillips screws are used throughout the device.
  • Manufacturer does not provide user-accessible repair documentation.
