Помощь
HTC Hero Camera Replacement
Нужно больше изображений
Несколько изображений сделают это руководство более понятным.
Нужны более качественные фото
Лучшие фотографии будут усовершенствовать руководство. Помоги нам, редактирую старые или сделай и загрузи новые!
This guide will illustrate the appropriate steps necessary to remove a damaged camera and replace it with a functioning unit.
  • Автор: Max Brown
  • Сложность: Средняя
Разделы
Инструменты
Связанные запчасти
Шаг 1 Camera  ¶
Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard. Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard. Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
Шаг 1 Camera  ¶
  • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
Шаг 2  ¶
Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free.  Repeat for the opposite side. Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free.  Repeat for the opposite side.
Шаг 2  ¶
  • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
Шаг 3  ¶
Pull the released camera enclosure away from the motherboard until it is completely free. Pull the released camera enclosure away from the motherboard until it is completely free.
Шаг 3  ¶
  • Pull the released camera enclosure away from the motherboard until it is completely free.
Шаг 4  ¶
Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it. Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
Шаг 4  ¶
  • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
