Помощь
iPad 3 4G LCD Replacement
Removing the LCD
  • Автор: Brett Hartt
  • Времени уйдёт: 1 час
  • Сложность: Средняя
The third generation iPad loses a lot of luster when its gorgeous retina display stops working. Use this guide to get your iPad back on its resolutionary feet.
Разделы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 LCD  ¶
Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
Шаг 1 LCD  ¶
  • Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
Шаг 2  ¶
Flip up the retaining flap on the LCD ribbon cable ZIF connector. Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board. You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
Шаг 2  ¶
  • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
  • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
  • You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
Шаг 3  ¶
Without touching the front of the LCD, lift the LCD off the front panel.
Шаг 3  ¶
  • Without touching the front of the LCD, lift the LCD off the front panel.
