Помощь
Handspring Visor Deluxe PDA Back Cover Replacement
How to attach the back cover and motherboard to the front screen.
  • Автор: Robert
  • Времени уйдёт: 5 - 7 мин.
  • Сложность: Средняя
Use this guide to separate the back cover from the front.
Разделы
Шаг 1 Back Cover  ¶
Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
Шаг 1 Back Cover  ¶
  • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
  • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
Шаг 2  ¶
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device. Be careful while opening the casing as there is a flex strip connecting the two halves. Be careful while opening the casing as there is a flex strip connecting the two halves.
Шаг 2  ¶
  • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
  • Be careful while opening the casing as there is a flex strip connecting the two halves.
Шаг 3  ¶
Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers.
Шаг 3  ¶
  • Disconnect the flex strip from the motherboard with tweezers.
