Введение
Replace a faulty display inverter with the display attached to your iBook.
Выберете то, что вам нужно
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
Rotate the spudger away from the display to pry the rear bezel off the front bezel.
Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
Close the display.
Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
Remove the large piece of tape near the right display hinge.
Remove the tape covering the inverter cable connector.
Remove the piece of foil tape near the center of the thin metal LCD cover.
Remove the Phillips screw near the right display hinge.
Use the tip of a spudger to remove the small spacer under the screw you just removed.
Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover.
Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
Remove the long piece of tape securing the display data cable to the LCD.
Disconnect the display data cable by pulling the cable away from the socket on the LCD.
Remove the pieces of tape holding the inverter and the inverter cables to the clutch hinges.
Disconnect the inverter cable by pulling its connector away from the socket on the inverter board.
Insert the flat end of a spudger under the middle of the inverter board.
Slide the spudger to the far left and right edges to separate the inverter board from the adhesive securing it to the front bezel.
Remove the inverter board.
7 человек успешно провели ремонт по этому руководству.
