Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Close the display and flip the computer over.
Remove the three hex screws using a T8 Torx screwdriver.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Remove the two Phillips screws on either side of the battery contacts.
Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Remove the single Phillips screw securing the DC-In board.
Lift the DC-In cable from the adhesive attaching it to the logic board.
63 участников успешно повторили данное руководство.
Прикрепленные документы
4 Комментариев
This was a really easy guide thanks. I had ordered a replacement DC in board but found after opening I could have probably repaired the existing one. It had been tripped over a few too many times. I think a bit of re-soldering on the connector where the tape covers in step 17 may have fixed mine. Now I have a backup at least.
Hi,
Does anyone happen to know the values of the L2 and L3 parts on this DC-in board?
I am looking to reuse them but I cannot find any specs.
Thank you and regards,
Vincent
