Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
You can install hard drives up to 9.5mm thick.
Выберете то, что вам нужно
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
Remove the following 11 screws from the bottom of the computer:
Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 11 mm Phillips in the lower right corner. (if present)
Four 14.5 mm Phillips.
Turn over the computer and open it.
Remove the 2 Phillips screws (3mm) from the edges of the keyboard area.
Remove the 4 mm Phillips screw from the lower left corner.
Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
Carefully disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips. (actual screw not present in image)
Two 4 mm Phillips.
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
If your iBook has Bluetooth, as discussed in the previous step, you will need to slide the antenna through the lower I-shaped hole in the shield before completely removing the shield.
Turn the computer over and disconnect the orange hard drive cable, removing tape as necessary.
Remove the four Phillips screws securing the hard drive to the metal framework.
Lift the hard drive up, carefully guiding the cable through the slot in the lower case.
Remove the hard drive brackets from the left and right sides of the hard drive.
Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
Use the transparent orange loop to disconnect the large orange ribbon cable from the hard drive.
156 участников успешно повторили данное руководство.
Прикрепленные документы
17 Комментариев
isit really possible change 320gb hard drive to ibook g4 1.33 14". i heard motherboard doesnt support bigger than 128Gb?
I put one in and now the machine doesn't recognize the drive.
I'm gonna just pull it out and use it as an external until I can figure it out.
I just went through the whole process and it worked fine. Used super duper to copy the original drive then restored using target disk mode and my MBP
Make sure that you print out the screw sheet (PDF), and lay out all the screws on the 3 sheets of paper. It makes it easy to keep track of all the screws, and you won't make a mistake when putting every thing back. Also, go slow and take your time. You don't want to rush on the HD replacement. It took me about 2 hours. The hardest part was take the case apart. You may want to look at a youtube video called "iBook G4 Hard Drive Swap", by smalldog.com. The video shows how the case comes apart, and puts your mind at ease when you hear the cracking sounds as the tabs are released. The instructions on the ifixit.com web site were awesome.
I too installed a 320 gb WD Hard Drive in a iBook G4. No problems. However, I did test the drive with one of my hard drives utilities to make the sure there were no write errors before installing the drive.
