Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
Rotate the spudger away from the display to pry the rear bezel off the front bezel.
Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
Еще один человек закончил это руководство.
