Введение
Plug your soldering iron in on the highest setting for later steps. This is a easy to intermediate level guide that requires a knowledge of soldering.
Выберете то, что вам нужно
Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
Grip the new microphone with tweezers and place in the slot.
Solder the new connections while using tweezers to hold the speaker steady.
