iDevices iGrill Power Delivery Wires and Springs Replacement
Выберете то, что вам нужно
  1. iDevices iGrill Power Delivery Wires and Springs Replacement, Power Delivery Wires and Springs: шаг 1, изображение 1 из 1
    • Place the front screen of the device on a flat surface, this allows access to the back cover. Remove the back cover from the device to access the batteries.
  2. iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 2, изображение 1 из 1
    • Remove the batteries from the device, allowing you to access the screws necessary for removal of the back panel.
  3. iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 3, изображение 1 из 2 iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 3, изображение 2 из 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm Phillips screws from the left side of the internal cover.
  4. iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 4, изображение 1 из 1
    • Gently and slowly pull the back cover off of the iGrill, exposing the power cables to the motherboard.
  5. iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 5, изображение 1 из 2 iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 5, изображение 2 из 2
    • Gently pull the metal terminals to the batteries out of their plastic holders.
    • Position the metal terminals such that you will be able to pull the plastic component that holds the batteries away from the motherboard.
    • Remove the internal cover from the device.
  6. iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 6, изображение 1 из 1
    • After you have peeled back the rear plastic covering, you will have access to the motherboard.
  7. iDevices iGrill Power Delivery Wires and Springs Replacement: шаг 7, изображение 1 из 1
    • From here, you will have access to both the metal terminals of the power transfer wires and the soldering points of the power transfer wires to the motherboard.
    • If any of these connections have been broken, repair them with a solder and soldering wire.
Заключение
Еще один человек закончил это руководство.
Kyle McElyea
Участник с: 02/16/16
259 Репутация
Автор 2 руководств
Команда
IUPUI, Team 3-4, Harley Spring 2016 Участник IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 270
