Введение
Consider this a meta-guide...that is, a guide that enables other guides. Before you remove any screws, you need to use the right bit, but getting those out of the tightly packed storage area and into your driver can be a chore in itself.
Запчасти
No parts specified.
  1. Note how challenging it is to remove a required bit from the kit. Argh!
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. Find yourself a rubber band...
    • Find yourself a rubber band...
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  5. Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Заключение
41 участников успешно повторили данное руководство.
aaronmiller
Участник с: 28.08.2011
1 244 Репутация
1 Guide authored
Один комментарий
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 14
За всё время: 2,609
