Введение
This guide will show you how to replace the wrist band on the iHealth Edge. You must take the device and remove the elastic band. This will expose the iHealth Edge and you will be able to put the new band on.
Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
Pull the elastic band away from the device, you should now have the device with no band as shown.
Place the elastic band into the channel in the side of the device shown in the picture. The band will pull into the channel and lock into place.
After pulling the band into place the guide is now complete. Your iHealth Edge should be ready for use.
This guide will show you how to replace the arm band.
