Введение
This guide will show you how to replace the battery on the iHealth Edge. You must take the device and remove the two piece that are stuck together using a blow dryer. This will expose the inside of the device to see screen. This is where we will begin to learn how to replace the battery.
Выберете то, что вам нужно
Remove polymer cover that is protecting the mother board, it should just come out when two halves are separated.
Use a spudger or plastic opening tool to assist the removal of the motherboard. Pry up on two tabs and the mother board will pop out.
You must remove the solder from two wires from the motherboard that are connected to the battery.
Еще один человек закончил это руководство.
