  1. Use your fingers to slide the battery case cover off in the direction of the arrows.
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
    • Remove and discard the old batteries.
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
  4. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  5. Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
    • Remove the back cover carefully; there are many wires that connect it to the device.
  6. Pull the stand backwards and around the system.
    • Pull the stand backwards and around the system.
    • Make sure the stand is positioned perpendicular to the speaker system.
  7. Locate the two small connection points for the stand. Using small needle nose pliers, pinch the end of the stand toward the side of the speaker case.
    • Locate the two small connection points for the stand.
    • Using small needle nose pliers, pinch the end of the stand toward the side of the speaker case.
    • Pop the end of the stand out of the hole in the side of the speaker case.
    • Repeat this step for the opposite side of the stand.
  8. 1. Position the new stand perpendicular to the speaker case.
    • 1. Position the new stand perpendicular to the speaker case.
    • 2. Align the bulbs at the end of the stand with the holes in the side of the speaker case.
    • 3. Gently push the bulbs into the holes of the speaker case.
    • 4. Pull the stand back around the speaker system.
Заключение
Lisa
Участник с: 13.10.2014
207 Репутация
Автор 2 руководств
Команда
Clemson, Team 3-4, Benson Fall 2014 Member of Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 152
