iHip Fold-up Portable Speaker Motherboard Replacement
Выберете то, что вам нужно
  1. iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: шаг 1, изображение 2 из 3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: шаг 1, изображение 3 из 3
    • Place the device on a flat surface as shown.
    • Remove the battery case cover and batteries.
  2. iHip Fold-up Portable Speaker Motherboard Replacement: шаг 2, изображение 1 из 3 iHip Fold-up Portable Speaker Motherboard Replacement: шаг 2, изображение 2 из 3 iHip Fold-up Portable Speaker Motherboard Replacement: шаг 2, изображение 3 из 3
    • Using a Phillips-Head #1 screwdriver, unscrew the four outer 1.0 mm screws and remove with tweezers.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Remove the back cover carefully; there are many wires that connect it to the device.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  3. iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: шаг 3, изображение 1 из 2 iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: шаг 3, изображение 2 из 2
    • Observe the location of the motherboard at the bottom center of the back cover.
    • Using a Phillips-Head #1 screwdriver, carefully unscrew all three 0.4 mm screws from the indicated locations. Set aside for reassembly.
    • Using tweezers, gently remove the motherboard from the back cover of the device.
  4. iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: шаг 4, изображение 1 из 2 iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: шаг 4, изображение 2 из 2
    • Note the connection point of each wire to the motherboard.
    • Using utility scissors, cut all the wires connecting the motherboard to the device.
    • Using tweezers, place the new motherboard in the exact position of the old motherboard.
  5. iHip Fold-up Portable Speaker Motherboard Replacement, Soldering the Wires: шаг 5, изображение 1 из 1
    • Read the manufacturer instructions for your specific soldering iron before use. Follow all safety instructions and solder at your own risk.
    • Position a strip of solder at the point of contact between the motherboard and each individual wire.
    • Solder the wires to the motherboard. Make sure to follow the manufacturer's instructions, as well as general soldering safety principles.
  6. iHip Fold-up Portable Speaker Motherboard Replacement, Securing the New Motherboard: шаг 6, изображение 1 из 1
    • Using a Phillips-Head #1 screwdriver, screw the original 0.4 mm screws into the correct places to secure the motherboard back in place.
Заключение
Amanda
Участник с: 10/13/14
201 Репутация
Автор 2 руководств
Команда
Clemson, Team 3-4, Benson Fall 2014 Участник Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 596
