Введение
Use the following steps to replace an individual speaker out of the iHip Fold-up Portable Speaker. The issue usually arises from a speaker with distorted audio.
  1. Use your fingers to slide the battery case cover off in the direction of the arrows.
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
    • Remove and discard the old batteries.
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  4. Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
  5. Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
    • Remove the back cover carefully; there are many wires that connect it to the device.
  6. Locate the two individual speakers on either side of the front cover.
    • Locate the two individual speakers on either side of the front cover.
  7. Use a plastic opening tool to scrape off the glue around the speakers. Gently pull the speaker up to detach it from the front cover. Desolder the black and red wires from the speaker unit.
    • Use a plastic opening tool to scrape off the glue around the speakers.
    • Gently pull the speaker up to detach it from the front cover.
    • Desolder the black and red wires from the speaker unit.
    • Use a hot glue gun to secure the new speaker. Solder the black and red speaker wires back in place.
Заключение
Lisa
Участник с: 13.10.2014
207 Репутация
Автор 2 руководств
Команда
Clemson, Team 3-4, Benson Fall 2014 Member of Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 3
За всё время: 539
