iHome IBT16 Auxiliary Port Replacement
Выберете то, что вам нужно
  1. iHome IBT16 Auxiliary Port Replacement, Base Plate: шаг 1, изображение 1 из 2 iHome IBT16 Auxiliary Port Replacement, Base Plate: шаг 1, изображение 2 из 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome IBT16 Auxiliary Port Replacement: шаг 2, изображение 1 из 2 iHome IBT16 Auxiliary Port Replacement: шаг 2, изображение 2 из 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome IBT16 Auxiliary Port Replacement, Auxiliary Port: шаг 3, изображение 1 из 2 iHome IBT16 Auxiliary Port Replacement, Auxiliary Port: шаг 3, изображение 2 из 2
    • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
    • Don't misplace the screws! Keep them in a safe place while working on the device
    • Make sure to ground yourself prior to continuing at this point
  4. iHome IBT16 Auxiliary Port Replacement: шаг 4, изображение 1 из 1
    • Using the plastic opening tool, pull the motherboard out of the casing
    • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
  5. iHome IBT16 Auxiliary Port Replacement: шаг 5, изображение 1 из 2 iHome IBT16 Auxiliary Port Replacement: шаг 5, изображение 2 из 2
    • Desolder the 5 points holding the auxiliary port to the motherboard
    • Once complete, it's as simple as lifting the port from the board
Заключение
Ryan Edwards
Участник с: 03/21/17
331 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 Участник UMass Dartmouth, Team S3-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G6
2 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 550
