Введение
After reading this guide you will know how to replace the micro USB port on an iHomeiBT16.
Выберете то, что вам нужно
Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
Using a lever like motion, push the opening tool down thus lifting the plate
Inside the iHome remove the two silver Phillips screws that are on the motherboard.
Take the motherboard out of the device, use the plastic opening tool to ensure the power switch doesn't get stuck.
On the other side of the motherboard unsolder the two biggest solder joints under the micro USB.
On the side of the motherboard that the micro USB connector is there are five surface mount solder joints at the back of the connector. Unsolder these five solder joints.
