Введение
This guide shows how to open the bottom of the iHome iAVS16 to gain access to the board housing the AC power and USB jacks.
Since the iHome iAVS16 is a compact device, any following replacement guide will use this guide as well in order to access the rest of the device.
Выберете то, что вам нужно
Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
Lift up the bottom of the device.
Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
Remove the two 1.7 mm Phillips #0 screws holding the power board in.
Carefully flip the board over.
Remove the red connector from its socket with a pair of tweezers.
